Tried two different suppliers who showed part as in stock, but both later refunded my order saying part no longer manufactured and/or available. Can these be rebuilt or refurbished, or is there any equivalent aftermarket part available? My issue is clean oil leaking from the upper exhaust port when the engine is running. Any thoughts?
Unavailable Part: F15MSHC Guide, valve 1 - 66M-11133-10-00
Originally posted by F15MSHC_99 View PostTried two different suppliers who showed part as in stock, but both later refunded my order saying part no longer manufactured and/or available. Can these be rebuilt or refurbished, or is there any equivalent aftermarket part available? My issue is clean oil leaking from the upper exhaust port when the engine is running. Any thoughts?
And what are you calling the upper exhaust port?
Google that part number. I seen it on Ebay and several Yamaha motorcycle sites. How much play in the guide? New valve stem seals? If you find one you will probably have to ream it to final size after installing.
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
