2004 Yamaha 15hp 4 stroke possible lean condition and overheating
  • boscoe99
    replied
    The plug is drilled out. Taking care not to insert the drill bit too far and damage the screw. Then screw a screw into the just drilled hole. Yank the plug out by pulling on the screw with a pair of pliers.
    Leave a comment:
  • 99yam40
    replied
    yes, if the head is getting close to boiling temp, then you have a water circulation problem.
    you just have to figure out where that problem is.
    when does it overheat?
    does it set an alarm or bring in RPM limitation?
    Leave a comment:
  • Bangstick310
    replied
    well how do you know the motor is running hot?
    you cannot clean a carb properly without taking it completely apart to clean all passages and jets.
    yes the pilot screws need to come out
    I did everything except pilot screw becuase of the plug in front. I’m assuming I have to drill it out to get access?
    also I can send pics of plugs when I get home later tonight. Plus I put a temp gauge around the plug area when running and if I remember correctly it was in the low 200 degrees and climbing before I shut it off.
    Leave a comment:
  • Bangstick310
    replied
    Carbureted Yams are known to run lean. Thanks to the EPA.
    Have you tried turning the idle mixture screw out a tad or two to try and make the fuel mixture a bit richer?
    There was a plug in front and I was hesitant to try and get it out. Do I drill the plug out. ?
    Leave a comment:
  • 99yam40
    replied
    Leave a comment:
  • boscoe99
    replied
    Leave a comment:
  • 2004 Yamaha 15hp 4 stroke possible lean condition and overheating
    I’m running hot, plugs show both lean condition and overheating condition if that makes sense, . I don’t know what’s causing it, I Rebuilt carb, new water pump, thermostat, new plugs, new oil,
    I should note I didn’t touch the air/fuel mixture screw because there is what I believe a plug in front of it and I can’t remove. I’m guessing I should drill out? Try to pull and clean?
    few questions can a bad oil pump cause overheating and result in showing a lean condition on spark plugs cause of high temps?
    I thought maybe a water issue but pulled the heads and water system is clear. No obstruction.
    Any help on where to start to diagnose I would appreciate .
