Hi, a bit puzzling...turn key ON, bendix gear on starter engages the flywheel but cannot turn it to start the engine. Checked/validated fully charged batteries/new batteries, all connections appear clean and tight. When I put cables direct from battery to starter the engine starts up. Then while moving forward and trim down the engine cuts out. However when engine is off, the tilt/trim works. To summarize; when I connect direct from battery to starter engine starts, when I trim engine cuts out. When engine is off, the tilt/trim works, So am thinking the starter is good, the tilt/trim is good...from there on I'm stuck on what to check next to fix this. As always, appreciate the counsel. Thanks in advance.
yamaha 150 troubleshoot ?
