Yamaha Part # 68F-85300-00, which is the Diagnostic Kit to hook a computer up to an HPDI for diagnostic purposes. One,is this part still available and Two, has anyone used it with any success? Trying to figure if twin 150 HPDI are running efficiently and if the software is the way to go to figure this out.
HPDI Diagnostic Kit - (Software)
Here is the part numbers that you will use to order.
LIT-YDIS1-23-00 YDIS CD-ROM
60V-WS850-00-00 USB Data Cable
This will only work on HPDI models and Fuel injected four stroke models, will not work on carb models or OX66 EFI engines.
You can order it here on boats.net, just enter those part numbers to the shopping cart.
YB-06795 Diagnostic indicator light tester will work. You will need a service manual for a list of codes and the tester will only show a code at the time the componet is malfunctioning, the engine ECU doesn't store the codes.
Originally posted by boats.net View PostYB-06795 Diagnostic indicator light tester will work. You will need a service manual for a list of codes and the tester will only show a code at the time the componet is malfunctioning, the engine ECU doesn't store the codes.
LB
Â
