Re: F90TLR, 2006 90hp.
I'm trying to determine if my Rectifier/Regulator (R/R) is defective.
The command link (CLink) is completely to the right side of the display (pegged). It indicates max V charge.
Putting a meter on the batt indicates a max voltage of 16.4V, this is too high.
The R/R is hot. Turning on all electrical and monitoring the CLink reveals the display is still pegged to the right.
The output plug for the R/R has 5 wires, 3 white, 1 red and 1 black.
My service manual is not clear on how to test the R/R. I want to do a continuity test on the full-wave diodes but can't find the schematic online. The manual says to measure the peak voltage at the coupler but doesn't give any reference to what wires at the coupler.
Can someone direct to a schematic diagram or tell me the procedure to test via the 3W, 1R and 1B wires.
I have YDS1.33 will that give me any detailed analysis? if so, how do I do?
