Here we go again guys. Here's what has been done to the engine so you dont have to look through my previuos threads. Replaced one of the 2 carbs. The older one (lower) has been cleaned with new kit. New fuel pump innards. Tank has been cleaned and dried. Fuel filter is clean. No issues starting now I have the 2nd carb choke valve. New fuel.
Was out running boat last night. Ran great for about 5 miles. As I was near the boat ramp i could hear it start to sputter at 3/4 throttle. This sputter im describing as violent. Noticeable shake to the engine and i can feel it through the tiller. I came off plane briefly then jumped back on same issue. This came out of nowhere ya know. It was late so I stored boat till today to work on it. I pulled the carbs out,dumped the bowls, cleared the lines, filter, and pump. Pulled plugs. Nothing major..they werent covered in fuel or oil. Put it all back together. No issues starting. Same result once I ran it.
I recently switched to synthetic oil and made it richer 50:1. Idle speed and mix were set to spec. Could this be a timing issue? One thing i have not checked is igition timing at TDC. Or could it be CDI issue? It cant be fuel, compression or spark. Tjose have all been checked. Im shaking my head.
