What would be the normal operating temperature of this motor at idle and running?
I started the motor and had it running in a barrel for a decent amount of time to try and get to operating temperature after the winter sit.
The starboard cylinder bank temperature was floating around 120 to 130 ish and port side cylinder bank was low around 70 but seen temps get higher to aroun85 90/ Is this normal, I replaced thermostats ,water pump, had injectors cleaned, fuel filters replaced, poppet valve inspected. etc. water peeing very strong. The only thing i didn't do was replaced plugs yet. what would cause low temp? should i be concerned?
Thank you in advance
