I am baffled. I have twin 1994 250hp yamaha outboards. I keep losing rmps at 3900rpms. It will fluctuated down to 3700-3600 then back up. It happens quick to where you can't miss it. When I run at 4200 rpms it doesn't happen. I tested all the coils and found one bad one and went for a ride and still happened just not as bad. So I swapped out the coils between the port and starboard motor. The problem remained the same on the same motor (the port). I changed all the fuel pumps same problem, rebuild all the carbs, same problem. swapped out the fuel filters same problem. I guess the cdi unit is next on the list. Any one have any ideas? Oh compression is 105 on every cylinder. will the pulser coil do this? Is there a way to test it?
thanks Tom
thanks Tom
