Hello to all,
I am glad that this forum came back to life again!
I have a problem with my outboard is 130 v4 1996,at low rpms between 1000-1700 rpms is shaking very bad like it missing a cylinder,so far i make some searching to identify the problem with no lack!What i've done
1)Cleaned the carbs twice on ultrasonic also i rebuild them and i got them also to a mechanic to cleaned them to!
2)Changed fuel pump 3)Work it from external tank!
4)Checked ignition timing by light and it's spot on
5)Checked Stator, trigger,cdi with dva adaptor all values in spec
6)changed spark plugs
The only thing that make it work better was when i turn pilot screws to 7/8 of a turn besides the 1 1/8 which was earlier but the problem is still there.
Also i have a picture of spark plugs and the right one it seems that is running lean and the others rich!
Also i have a video at 1300rpms that is the problem obvious https://youtube.com/shorts/IN9JYe2blkg?feature=share.
Any help i will appreciate it.
