water pump kit - 90TLRA
  • water pump kit - 90TLRA
    What is in a water pump kit for a 2002 90TLRA?
    is there a complete assy from housing/gaskets/impeller/key avail for the 90TLRA?
    thanks.
    02 Sea Hunt Triton 172
    02 Yamaha 90HP O/B
    no
    the pump kit is complete but you have to get the housing seperatley.
      And if your water pump was never run dry/overheated/melted then you may not need to replace the plastic water pump housing....my 1999 motor still has the original housing.....
        2002 90TLRA Yamaha Outboard LOWER CASING DRIVE 1 Diagram and Parts
          thanks guys, I did order a service kit to have on hand when I`m ready...
          02 Yamaha 90HP O/B
