got dual 250hp OX66. would like some advice on how to proceed
1: our starboard engine has for a long time had issues with cold starting. i have come to the conclusion that the engine is not cranking fast enough and is not firing injectors as a result. winky blink gave a code for pulser coil but the real issue is slow cranking. once started and warmed up, engine runs good and starts up no problem. batterys are new (900CCA starting), battery cables to engine are new, cable from relay to sterter is new and larger, swapped starter with the port engine made no difference. using a jumppack on the battery does help it crank some faster and will fire up but battery tests good. when putting an amp gauge on each starter cable, this engine draws a good amount more amps than the port engine does (i think like 270amps verse 200amps IIRC) like the engine is struggling to turn. recently replaced waterpump to make sure it was not causing extra resistance, shaft spun fine to lower unit
engine was rebuild few good few years ago, not sure when this issue started to occur but it might have been around the same time. is there a spec for how much torque it should take to spin the engine with a torque wrench? anything else i should try?
2: a recent issue the starboard engine, with key on engine off, the fuel pump will occasionally keep running. normally it should stop after a few seconds. i normally take this as a sign of a failing computer in the automotive world. am i right to assume?
3: another very recent issue with this starboard engine that just started yesturday. it started this tendency to diesel after turning the key off. when i turned off the key, it ran for 5 seconds before turning off. it did this 4 times in a row but then stopped doing it. it sounded like the reason it finally stopped was because it lost fuel pressure more than lost spark. this is another indication i might have a bad computer. unless its something like they key switch is bad
4: port engine starts up and cranks great. but it coughs quite abit and dies. usually takes a good 20 keystrokes for it to fianlly warm up enough that the coughing becomes minimal and doesnt die as frequent. idle rpm seems good, throttle blades and TPS adjusted to spec. wondering if possible reed valve issue. recommendations before i take the intake off to inspect them?
