Originally posted by MattF115
View Post
F115TXRD 2005 surging
my 2018 F90LB had some kind of a similar problem, surging under speed, then it was good for a while, and then it started doing it again. Then after that very rough at idle ( something that was not happening at the beginning of the surge problem) to make a long story short, only 2 cylinders were working because two Spark Plugs were bad, they look fine just by looking at them but they were bad, some people dont even change spark plugs every year and dont run into any problems, well i had not one but two bad sparkplugs, and these were the ones that came factory with the engine. So i guess you could try that.
Originally posted by MattF115 View PostI wish I could say that I got a video of what it is doing trying to upload but having a problem doing that. It’s like someone hit the key to shut it off but then turns back on.
clean all battery connections, both + and -., all ends of cables, maybe a bad connection loosing power to ECU
Is there values for metering the coils and stator maybe i can start looking for that as it seems to get worse with heat when i first put it in the water it ran at 5800rpm for 10 min then when i slowed down and turned around and started going again it started to crap out.
Originally posted by MattF115 View Postheading back to the dock all of a sudden it kicked out put a fuel gauge on it under load maintaining 42 psi and when the engine kicks out it definitely loses fuel pressure but its electrical like it its not kicking out as an a lost fuel pressure
but if the crankshaft is turning, the pump should be continuously running
and rail pressure should be constant
Originally posted by MattF115 View PostIs there values for metering the coils and stator maybe i can start looking for that
on an EFI 4-stroke all that does is keep the battery from discharging
ÂÂÂÂÂ
