1997 C90 TLRV
My C90 kicks up a lot of spray in front of the engine when I run my boat at planing speed. Trimming out only helps a little. Some of that spray ends up coming back into the boat. I've been told that once upon a time, there was a "Spray Deflector" / "Splash Guard" (not sure of the proper term) that was mounted on the high thrust version of this engine that was much more substantial and kept that spray down.
My motor is mounted high enough that the spray deflector is not buried in the water and unable to do its job. The cav plate is where it needs to be in relation to the water. My hull has a pocket in the transom that sends spray up towards the engine, and that little spray deflector on the C90 is all but ineffective.
Here are some pictures to illustrate what I'm looking for-
Does anyone happen to know a part number I can drill/bolt on to my engine? They seem to be readily available for older OMC engines, but I can't find anything for Yamaha. If no part number, has anyone fabricated something like this?
