Yam 25 NEO 2 stroke
  • Yam 25 NEO 2 stroke
    is there an alternative part number to the thermostat for this engine
    the number on the housing is 6H4 but I cant trace this anywhere any help appreciated
    Mr. Almetelo needed
    The prefix for the housing will not necessarily correlate with the prefix for the thermostat itself. A 6H4 prefix indicates the housing was first used on a 40 HP model but that does not mean it was not used on a 25 HP.
    Have you talked to your local dealer about getting the part number for the thermostat, or the thermostat itself?
    What is the complete identity of your motor? A 25NEO is not offered here in the USA so it will not be available in our parts catalogs. If we can find a USA equivalent model then more than likely the thermostat part number will be one and the same.
    Maybe Mr. Almetelo of Portugal can tell us.
      Many thanks for help
        6E5-12411-02 is the thermostat for a 1989 25NEO. If you let us have the full serial number for the engine I can narrow it down. The earlier model used a 6E5-12411-00.
        Most of the housings for that motor were the 6L2. That was a Euro model only.
        Yamaha 6E5-12411-02 Thermostat if in the UK or 6E5-12411-02-00 YAMAHA THERMOSTAT if in USA :-).
