Yamaha 2002 225 TXRA. Motor starts fine, runs fine for 2-4 minutes then stalls. Yamaha master Tech ran diagnostics and eventually gave up.
Squeeze the primer bulb (new) and it keeps running. Same symptoms on remote tank. I can hear the brand new LP pump cycling on and off.
F filter going into VST is new and hoses are clear. Clamps are tight.
Motor stalls at 700 rpm or 2000 rpm, no difference. Have replaced check relief valve and cleaned VST. Something is keeping fuel from filling VST I think as manual pump via bulb keeps it going. VST pump was replaced two years ago. VST filter is clean. VST input valve and float appeared okay when I cleaned it but not sure. Is there anything in the pump driver or ECU that could be causing it? Here is an odd thing, motor will start and run with same symptoms with fuse removed. Does that mean anything?
Have not replaced air vent check valve but I cleaned it, but would that keep VST from filling?
Have had no boat since 7/4. Unhappy wife and kids...tnx!
