I recently went with a friend that had his outboard motor serviced. I witnessed a mechanic use a sharpie to mark the drive shaft and water pump housing. He did in the same manner I mark my trim anode to position it in place upon install. He then turned the drive shaft clockwise to mount the water pump housing onto the impeller. Then he aligned the sharpie marks and installed the lower unit splines without resistance.
I normally have to turn the lower unit to align the splines a bit and then double check for the shift shaft and water tube. He also used a tie down strap to secure the lower unit and slowly bring it up to position the shift shaft and water tube. Used an inspection light and thin nylon trim tool to slide in and move the shift shaft tube in place.
Do you guys use a sharpie to mark the unit when it is removed and then align the marks?? Never heard of this method in any forum and just happened to observe it. It seems like a great method and worked.
