HELLO ALL i decided to replace a water pump on a 60 hp enduro which was working A OK i pulled the leg off but the shift shaft stayed on the upper leg after removing it from a stuck spline i find i cant find the spline in the lower leg gear change i think the gearbox is in gear I HAVE TRIED TO disassemble the lower leg but cant remove the gears hoping for help himinshedhttp://www.yamahaoutboardparts.com/images/smilies/confused.gif
Lower leg shift shaft 60hp enduro
you will have to get the lower unit apartOriginally posted by HIMINSHED View PostHELLO ALL i decided to replace a water pump on a 60 hp enduro which was working A OK i pulled the leg off but the shift shaft stayed on the upper leg after removing it from a stuck spline i find i cant find the spline in the lower leg gear change i think the gearbox is in gear I HAVE TRIED TO disassemble the lower leg but cant remove the gears hoping for help himinshed http://www.yamahaoutboardparts.com/i...s/confused.gif
A complete motor model # might help
Here is a thread on a C60 I took apart in case it might help you some
http://www.yamahaoutboardparts.com/f...g-th25042.htmlLast edited by 99yam40; 08-24-2015, 06:03 AM.
