Originally posted by oldmako69
View Post
Spark plug replacement 2006 F60 2300hrs?
Why not use anti-seize? I use it on damn near everything on these engines. If the answer is "proper vs improper torque" I have read that argument.
Leave a comment:
I have never seen the gap change. I just replace every two years to observe the plug condition. Then I just install new plugs. No point cleaning threads and install the old plugs. Just put in new gapped plugs from NGK (I do check the gap first). Like checking an impeller. Why not just install a new one??
Leave a comment:
Replace them every two years. This ensures you are using properly gapped plugs. Also, the plugs will not seize. The health of the engine can be observed based on the condition of the plug. I barely use my motor and change my plugs every two years. Please do not use anti-seize when changing them and use NGK plugs as noted by your owners manual. Torque the plugs to the OEM spec.
Leave a comment:
Originally posted by boscoe99 View PostMy 2005 Ford F150 with a mere 100,000 miles on it has the original plugs. It runs as well as they day that I got it.
If it ain't broke, I won't be fixing it.
I have been replacing F150 Yamaha plugs every two years. Roughly. Paid 9 bucks each last time. Probably 25 bucks now.Last edited by pstephens46; 06-03-2022, 08:41 PM.
Leave a comment:
Leave a comment:
I’ve always inspected, cleaned and re-gapped plugs as necessary and continue to run them….they can last for years…
Leave a comment:
Is there reason to replace spark plugs if the engine runs like a swiss watch?
I'm original owner, I did replace them once @ the 500 hours mark
Also just out of curiosity what is the life expectancy on these outboards? (fresh water use)
ThanksTags: None
Leave a comment:
