I recently added a new 24v ***** motor up from 12 volt and wired with a jumper and 50 amp breaker. After connecting all accessories, jumper, ***** motor and motor to batteries I ran into the problem of tilt, accesories working, ***** motor working but engine won't crank. Can someone please assist me? I really don't want to take it to get serviced. Thank u
50 hp 4stroke won't crank. Tilt works
Yes I did accidentally have it wired 24v to the motor. What could the damage possibly be? Is there a fuse that may be bad or have I screwed the pooch. Jeez Thank uOriginally posted by 99yam40 View PostNot sure that you did, but You should not include your 12 v starting battery in the 24 volt *****ing system.
