I've been wanting to try replacing my oil pump for a while, but I'm unsure about which part number is correct. It is slow to send oil up to the top cylinder of my 3 cyl. outboard. I watch the clear oil lines at idle and it just creeps up to the top cylinder, doesn't really start flowing til you get it off idle. as a result I have usually mixed my fuel 100:1 just in case its failing. When I look at the part numbers online I see the original Yamaha number is 6H4-13200-01-00. However, some sites show this has been superceded to a 6H4-W1320-09-00. And the pictures of this appear quite a bit different than my pump. The first pic shows my original pump as installed with the 3 oil injection lines all in a row. The second pic is from shots I have seen online of the "newer" style. The 3rd oil injection line seems to be in a different location. Does anyone have any experience with these 40HP injection pumps. Does the newer style give better output? Thanks much in advance!
