you have not answered the question of what year is this motor.
also have you disconnected the shift shaft somewhere?
those #6 and 13 may hold things snug if corrosion has set in,
but it moves even a little bit you should be able to keep working it back and forth.
spray some penatrating oil in areas you think the problem is.
But if you have not disconnected the shift shaft that could be the problem.
also those driveshaft bushings
