I bought a boat with a 2004 F150 and the boat needed some work. While going through some things I tried testing the alarm by turning the key to run with the lanyard disconnected and it didn't sound. I ohmed out the lanyard switch at the ignition wiring and it checks out. I took off the buzzer and hooked it up to the battery and it made a bunch of racket so put it back on, then tried to unplug the temp switch and jump it and still no alarm. With the lanyard off and the temp switch still jumpered, I measured pink wire on the 10 pin plug and it was 13v.
I'm assuming this pink alarm wire is supposed to be driven to ground to activate the buzzer? Does it get driven to ground by some relay or ECU directly? Is there anything else I can check?
Thank you!
Michael
Thank you!
Michael
