2016 F70 Issues
  • Gatorlizard
    replied
    You asked in a previous post how to rig up a pressure gauge with the cowl on..Why do you need the cowl on if you can make the problem happen in the driveway? Does the cowl need to be on for it to start acting up?
    In the driveway with the cowling on.
    Leave a comment:
  • panasonic
    replied
    Originally posted by Gatorlizard View Post
    I don't have to worry about losing the cowling in the river.. I can reproduce the issue at will in the driveway repeatedly. Not sure what I did to get the warning (Also remember, people on here are trying to help you.. be kind).
    Leave a comment:
  • Gatorlizard
    replied
    Lots of the new folks take Yam the wrong way. He is black and white. An Electrician. Follow the steps or you may die. A matter of fact guy. He doesn’t intend to aggravate.
    I don't take him the wrong way at all. I think maybe he takes me the wrong way.
    Leave a comment:
  • Gatorlizard
    replied
    Take pressure gauge with you and when it happens simply take the cowl off and hook the gauge. If worried about losing cowl a overboard...rig up a small lanyard to it before you go out.
    Also remember, people on here are trying to help you.. be kind.
    Leave a comment:
  • pstephens46
    replied
    Leave a comment:
  • panasonic
    replied
    Leave a comment:
  • 99yam40
    replied
    then do it your way
    Leave a comment:
  • Gatorlizard
    replied
    run with pressure gauges hooked up to see if there is a problem with one of both
    if you say spark is not the problem, then you need to find out if or why fuel is a problem
    How do you monitor the gauges with the cowling on? I guess you could rig longer hoses and run them through the cowling vents. That's the problem... Remember.. when it shuts down you only have 30-45 minutes to diagnose the problem before it isn't a problem anymore. If I was on fresh water I could probably put louvers in the cowling and live happily every after.
    Leave a comment:
  • 99yam40
    replied
    Leave a comment:
  • Gatorlizard
    replied
    how many pumps have you had do this?
    why would a pump overheat?
    running without fuel to cool and lube it is a good way to kill a pump.
    test and prove things, do not just guess or think something is not a problem
    have you tested to make sure the hp pump has power when it will not run?
    is the problem the ecu is not providing the negative to run the pump?
    what tells the ECU that pump should be running?
    testing if better than throwing parts and hoping
    Maybe you didn't read the entire post. With the motor shutting off after running 35-45 minutes and starting normally after sitting for 45-60 minutes there ain't a whole lot of time to trouble shoot anything. What do you think I need to check first? Where are you? I'd gladly pay you to diagnose and fix the problem.
    Leave a comment:
  • 99yam40
    replied
    Leave a comment:
  • Gatorlizard
    replied
    I don't think the VST is running dry.. After cooling off it starts with just a bump of the key. Wouldn't that eliminate the VST being dry and the lift pump? When it shuts down it still has spark but the high pressure pump doesn't run until it cools down.
    Leave a comment:
  • 99yam40
    replied
    Started in the driveway today and it shut off after running at 2000rpm for 35 minutes. Obviously it isn't fixed!
    monitoring fuel pressure into and out of the VST might help figure out, or at least eliminate some potential problems from the list
    Leave a comment:
  • Gatorlizard
    replied
    Leave a comment:
  • Gatorlizard
    replied
    I would ask for the old pump back. Hopefully the new pump will solve your problem. It just seems a bit odd to me that it would fail in such a manner as you described..usually fuel pumps quit and that's that..they dont come back to life after sitting for awhile. Just saying. Hopefully I am wrong.
    I am not qualified to agree or disagree with you. I'll let everyone know the outcome of the fix.
    Leave a comment:
