Originally posted by rodbolt17
View Post
Need help whit the "automatic choke" on a F50 2000 model 4stroke
Originally posted by 99yam40 View PostLooking at the wiring diagram posted I would like to know/understand how the thermoswitch is going to allow voltage hot or cold unless it is closed instead of open
The accelerator pump stuff looks to be a cluster f___ as well.
If three parts are needed to accomplish a task then lets use ten times three seems to be Yams modus operandi.
Now just imagine one simple carburetor, having just one choke plate and an internal accelerator pump, feeding all four cylinders.
What is it with the Japs and their love of carburetors? I am surprised they don't use four separate fuel injection systems on the latest four cylinder F50's.
Too bad there is no throttle body fuel injection retrofit modification for some of the older carburetted models.
Originally posted by robert graham View PostI could easily explain this to you guys but believe it'll be best if you can figure it out on your own....I mean, how are you going to learn?.....Mean time, I'll just keep my old C90
....good luck!
meanwhile i found a garage that can take the engien in tomorrow, just gotta drive 3 hours each way and one ferry ride....
but ill keep ya posted as soon as they say whats wrong
My Yamaha FZ has less than half the displacement of a Harley (one carb, air cooled), twice the HP, almost 3 times the RPM limit, 14,000 RPM, about the same mileage, 47MPG's around town..
So with the advancements, comes the performance.
Dink with any machine incorrectly, you'll have issues...
Originally posted by TownsendsFJR1300 View PostWell, yes it certainly would be easier. But, its going to be more efficient (when working properly). My 600cc, 100 hp Yamaha motorcycle, Inline 4, is FI'ed, two, two barrel throttle bodies, water cooled, 4 valves per cylinder, overhead cams, etc...
And not to disparage your Yamaha motor cycle, as I have had two of them and they were good, with all of the added stuff on your bike, it is still not a Harley. It is just a rice burner.
In a motorcycle I might see the need for some gizmos for added performance. In an outboard motor, who's forte is supposed to be about reliability, I think not.
Adding more makes things less!
That usually means less weight, less fuel consumption, less pollutants.
With outboard motors weight is a prime factor, surprisingly by adding multiple components weight is reduced. You could not design and make a 50hp O/B lighter with only one carburettor etc!
Growing up in the 60s there was something I realized. All modified motors were worked on a lot more than factory motors.
Yes they had more HP and performance, but they were always breaking or being modified some more.
I never had the money to do mods very much so I was happy to have dependable transportation with stock stuff
Things have come a long way in the past 50 years and they hold up well too
Originally posted by boscoe99 View PostWhy not four single throttle bodies? Five valves per cylinder. Twin variable camshaft timing. Direct injection. Nitrous oxide injection. Think of the extra performance.
Doesn't handle worth a $..t, EVERYONE has one. Most, MC wanna bee's..
I'd take my Yamaha any day of the week over a Harley.
I had three bikes at one point and sold all but this one as it IS my favorite. I don't need to prove myself to anyone.
BTW, I can easily afford to buy any HARLEY outright for cash, but don't want one.
Here's my old Wide Glide, single carb(no syncing carbs), air cooled;
Parked in front of the same garage as my rice burner;
Only time I tried riding a full dressed Harley was on a cop bike that was brought in to the shop I was working at in the middle 70s to get an inspection sticker.
It was like riding on and balancing a car split in half on 2 wheels.
Slow moving was a pain for someone used to smaller and lighter bikes.
Most like the sound they make I guess.
I dropped the M off of my drivers license many years ago
Too many people running into bikers say they did not see themLast edited by 99yam40; 08-03-2015, 07:15 AM.
Originally posted by 99yam40 View PostOnly time I tried riding a full dressed Harley was on a cop bike that was brought in to the shop I was working at in the middle 70s to get an inspection sticker.
Most bikes nowadays, like marine engines, are FI'ed with overhead cams (the Harley twin cam has two cam's in the block with pushrods), overhead valves at least...
Slight thread de-rail to say the least, but just pointing out how far backwards you go, the less performance you get...Scott
like I said, its a silly system.
its also a difficult system to set up correctly.
I think the procedure to properly link and sync the carbs and choke is about 6 pages long.
worst is when the untrained have taken a screwdriver and attacked every adjustment they can.
crossing every fiber in my body its something easy adjustment/fix and its back on the water(and most of all, cheap, cheap fixes are great fixes :P )
ÂÂÂÂÂ
