Drive Shaft shimming???
  • Drive Shaft shimming???
    Planning to change my corroded drive shaft, i need to know if this job will required reshimming??
    Is it corroded enough to effect it’s function as the drive shaft?……otherwise clean it with abrasives, grease it and leave it alone…
      shafts should the machined to a very good tolerance, the case change is usually when re-shimming is needed.
      but the shop manual should say what to do
        thank you guys for your input, i will check the manual. Well the shaft is in bad condition, dont know if its worth to replace it for now. I already bought a new one, but if its too much of a pain i will leave it alone for now, and install it later on.
          Surface rust is all I see.
            I agree….a 3M Scotchbrite abrasive pad is good for rust removal and polishing…..clean top splines with wire brush…Then a coat of grease over the entire shaft should help prevent further corrosion….
              thanks everyone, will do that.
                I would use strips of emery cloth to clean that shaft.
                you can clean about 1/2 around the shaft with maybe 2ft long strip buffing like the old shoe shine guy
                work your way down the shaft and then turn the shaft 180
                  will do, thanks a lot
