I've got a heavy(9000lbs) Boston Whaler with twin 250 2 strokes on it. Max RPM was 4900 trimmed all the way in. 3 blades on it now with 21 pitch. What pitch should I go too? Is there any difference between a 3 and 4 blade with a 19 pitch? Not much interested in speed.
Propellers
"Max RPM" is found by running wide open, with the trim as high as it will go until you either ventilate or speed drops off, instead of climbing.
Prop the boat to get into your specified range with your typical/normal load and you should be just fine. I prefer to be on the higher side of the range so that when I'm running a heavier load, I'm still not bogging the engine. For those few times when I'm running light, I can control the Max RPM with throttle.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
props
Hi Zeno,, a three blade is a good choice of prop for such a app..a 4 blade is usally for more bow lift..Dennis's post is spot on...also when blindly trying to find the right pitch prop..it not a good thing to start changing number of blade's... going up one (1) inch of pitch will lower RPM 200...going down one (1) inch will raise 200 rpm.....in general...a 21 inch pitch prop in this app,, sounds WAY too much !!
