Looking for some input from members who may have experienced a similar issue or are knowledgeable regarding this problem.
Because of supply chain issues, the dealership where we purchased our new Key West FS263 with twin 200s mounted the engines as opposed to the manufacturer doing so at the factory. The boat was delivered in November 2022 and used roughly three days a week since that time. – a little over 50 hours on the engines.
Recently while adding some electronics, the independent technician working in the bilge noted that the lower port engine bracket bolt had apprently been overtightened cracking, at least, the cosmetic fiberglass inside the transom and exposing the core (picture). Which resulted in a small leak when the boat is in the water (the boat is lift stored).
The logical assumption is the bolt was overtightened. However, it also seems logical that bigger washers would have provided more back plating by spreading the stress over a larger area of the transom. Or better yet, a lower bolt transom plate would have provided the same load distribution on the transom as the plates with the Key West logo on the two transom bolts above the water line.
Given the boat just went to the dealership to have the fiberglass repaired and the situation rectified, and they have not started on it yet, should we be asking for larger washers for all four lower bolts or for a lower back plate the same as the top tow bolts be added? Also, any thoughts on what sealant is recommended for the bolts below the waterline would be appreciated.
We love the boat and even more so love Yamaha outboards. This is our fourth boat since stepping down from inboard diesel powered larger models 13 years ago and we would not even consider using any other outboard engines. Our issues here are with the dealership and the job their service department did mounting the engines – not Yamaha. We just want to make sure the engines where mounted properly to begin with and, certainly, that the fix they are proposing is correct and permanent.
Thanks in advance for any thoughts
