I have just bought another boat with a 2013 F100 4 stroke, I have swapped my Lowrance HDs units over and wired everything up and set up the nmea 2000 network. Went to hook up the interface cable from the F70 on my old boat but can’t find the white plug to connect to. Does the F100 have a different set up ? Regards Mick
2013 F100 nmea plug
I have just had another look and. I’m quite sure that there is no white plug on this engine there are also no pink wires, I know what I’m looking for as I’ve just disconnected them from my F70 to put on the F100. The only connector not doing anything is a grey 3 pin with 3 wires red with a black tracer, white with a black tracer and a black, it’s got me beat
You may "not" want to read this but, by that model and serial number here in Australia, that engine is listed as a 2005 model, I'm not sure where you are from, but prob UK by yr user name, i dont think 2005 model has the NMEA connection available, from memory that capability was introduced 07 or 08 ??Originally posted by Pommymick View PostEngine ID is F100DET 609 L 1000106 N. Definitely no plug in the location on the photo
