need lots of help! my 1987 yamaha 70hp2 stroke lost #2 cylinder compression.
pulled cover off side of engine to view piston sides and the rings.
oh oh! aluminum smeared on side of piston rings and groves in piston side.
pulled head and top of piston has no holes.
cant afford to replace so hope it is found to be repairable after inspection by machinist. we plan on doing all disassembly and reassembly if found to be repairable.
how can i tell the cause and fix same before lighting the fire again.
any and all help and advice will be greatly appreciated!
thanks,
chris
thanks,
chris
