Little rust on lower unit shaft of my nearly new F70
  • Little rust on lower unit shaft of my nearly new F70
    Took the lower unit off for the very first time for the 1st 100 hour maintenance on my 2020 F70.
    There's a little surface rust on the shaft. Is that normal?
    Yes it is.
      Outboard driveshafts are made of a type of more or less stainless steel, but they can show rust some especially if run in saltwater environment. Yours has a bit of corrosion but should be no problem. When I drop my lower unit I clean any corrosion from my driveshaft and splines with a 3M Scotchbrite scrubbing pad and apply a thin coat of marine grease to the entire shaft and splines….helps keep the corrosion down….
        Thanks, always appreciate the advice you take the time to give here.
