Have a quick question regrading Yamaha outboard spark plugs. Do you guys clean the mating threads before tightening to spec.?? Do they need to be cleaned before tightening the plug?? I just remove and insert a new plug (properly and I do not cross thread). The plug is installed by hand using a spark plug starting tool. Then I torque to the 13 lb.-ft. spec. using a digital torque wrench rated for 20 lb.*ft max range.
I install as per NGK requirements. No lube applied as directed on the instructions. Never cleaned the mating threads and use a new plug and check gap (always correct as per Yamaha spec.). Should mating threads be cleaned before applying torque??
In the case of hard to get to plugs like on an inboard V6 (the middle ones are sometimes tough depending on what brand manifold), I just use a short piece of rubber hose over the insulator.
