Descaling
  • Descaling
    I purchased some starbright motor descaling fluid . Do ineed to remove the thermostats from the motor before descaling it? I have a yamaha sx150txrb outboard my engine alarm will go off after it is at idle . I can give it some throttle and the alarm goes away. So im thinking it might need cleaning.
    It would be best to remove the stats so the solution can run thru every place in the power head freely.
    but a stuck open PRV can cause that type of problem along with the water pump needing replacement
      That would be the first thing that I would check.
        Ok thank you so much , I will look into this.
          Where would I find the Prv in parts breakdown ?
            number 19
            Yamaha Outboard 150HP OEM Parts Diagram for Cylinder Crankcase 2 | Boats.net
                Thank you, you guys are awesome!!
                  Saltaway or white vinager
                    Muratic acid can be used if you have experience. Shortly !!
