How does the system know when to pump oil from the larger main tank to the smaller feed tank on the motor? Is there a float switch located on the smaller engine tank which turns the main pump on when the engine fed tank falls below a certain level. Then when the small feed tank reaches a full level the switch will turn the pump off to prevent over fill and the overflowing of the feed tank.
My Yamaha will fill the feed tank, the pump will pump oil from the main tank only when I engage the toggle switch on engine. I took the alarm sensor out of the small tank and turned it upside down to replicate a full feed tank and to silence the alarm. I turned on the power switch and observed the small tanks oil supply line; I had disconnected it from the tank, but the pump never came on. (no oil) I then turned the sensor upright. the alarm engaged but again the pump never came on and no oil was sent.
I then did the same procedures as above except with the motor at idle, and the pump never came on. Again, if I hold the emergency toggle switch the oil pump comes on and will fill the small feed tank but if I am running at 1/2---3/4 throttle for a while the alarm will sound the motor will slow. I have to remove the cowl and refill feed tank by way of the toggle switch. (WHAT A PAIN) So, is there an oil level sensor associated with this system that regulates the pump to come on and off per the oil level in the feed tank?
Or am I missing some other cause and effect.
Please advise!
Please advise!
