In addition to my Yammie 15, I also have a Mercury 4-hp 2-stroke and, at the risk of losing my good standing with this form, I wonder if someone could suggest a cure for my troublesome Merc? I haven't found the Merc Forums very responsive.
The engine: 2016, SN-1B680388
Original problem: The engine was running rough in the mid power range, not just during acceleration. And it made little difference if the engine was warmed up. It started fine, idled fine, and smoothed out at maybe ¾ throttle and above.
Compression pegs out at 105 psi. Replaced plug, filter, carb (single mixture screw), fuel pump, tank, hose, and ran three tanks of premium gas through it. I think the fuel system is good. I seem to have good spark using a tester. Coil: Primary Winding Resistance- 00.5 ohms. Secondary Winding Resistance- 6.29 killi ohms. Used a pencil in the spark plug hole to bring the piston up to TDC. The mark on the fly wheel is about ¾ of an inch off the mark on the casing.
I replaced the new carb (about a year old), with the original carb, rebuilt with a kit.
Current problem: Engine starts with the original carb and idles for two minutes and dies.
I suspected an air leak. (I had switched the plumbing to use an external tank), but bypassing all that and running a separate fuel hose with filter directly to the fuel pump did not improve matters. Next, I cleaned the new carb (brass wire, carb cleaner, compressed air), and swapped it for the original carb.
Problem still exists: Engine starts, runs ragged a couple of minutes, then dies.
What am I missing, here? Any suggestions as to how I should proceed are much appreciated.
Bry
Bry
