2006 f250 225 hours. Starts and idles fine. Gets on plane for about 20-30 seconds and starts to sputter and lose power. Back it down to an idle for a minute or so and it will run back up even to WOT but dies off again. Filters are fresh. I even pulled the fuel water separator and cut it open and it looked pristine. While we were troubleshooting on the water I removed the cowling and ran it up. The primary filter assembly stayed full of fuel so there does not seem to be an issue of getting enough fuel. Any ideas?
Losing power
Primer bulb does not flatten out. That was the first thing I checked as I just fixed this on a friends boat. If there was a restriction I would expect the primary filter on the motor to run dry which it never did. I guess it's possible there could be a restriction after this filter but I'm still leaning towards bad fuel. I am going to try a remote tank like you suggested.
The fuel water separator and primary filters are new. I have been running the standard Yamaha spin on filter but will be swapping in a racor this weekend. I like the fact that I will be able to see if there is water in the fuel filter. I first suspected water in the filter but this was not the case. I had s similar problem last year. Ran fine at cruising RPM but hesitated at WOT. After about an hour it ran fine and didn't have any more issues until now. This time it's worst as I can't even run at cruising speed.
I have not check the VST filters.
Originally posted by 99yam40 View Postas I said before you have lots of filters to be looking into, even the injectors have filters/screens after all the others it runs through.
pressure testing could show where the restrictions are
My mate's new boat took six month's to sort out why it did not work properly, involving coast guard tows and visits to dealer. He did not enjoy boat ownership at all. He also snapped his achillis when he angrily jumped off his boat for the fifth time at the dealer.
Finally they found a kinked fuel hose due to their poor installation. He is still too scared to go out in his boat in case another alarm goes off again!
Boating was supposed to be fun!! Good luck.
fixing outboards 8 days a week
DONNIE>>>I have been running the standard Yamaha spin on filter but will be swapping in a racor this weekend. I like the fact that I will be able to see if there is water in the fuel filter.,,,, Capt "K" Baja reply....Been gone for a while and just ckd a few threads and this one won my simple reply !! Do NOT use a clear plastic bottom RACOR on a outboard !! NO,,NO,,NO,,the UV'S will eat it up and leave you stranded,,,,The Reason that all outboard F/W filters are like a oil filter is that it live's in the sun/salt..the unit you thinking about using is for a inboard,,,Racor's (Parker) are great !! but that unit is not for a outboard....Read the fine print..or ask a expert !! ....Last edited by bajakeith; 07-12-2015, 02:23 AM.
Â
