I'm having sometimes problem with idle speed. When i start engine they imediatlly turn off. If i pull throttle on command and then start the engine works great, but soon as i close throttle on command engine stops.
When is this problem present I unscrew three bolts on the top of the throttle body and spray some wd40 in it and the screw three bolt back of idle control valve and then start the engine works everything perfect for about two weeks and then again.
The big problem is because yamaha don't sell idle control valve separatlly, only with body throttle control, which is almost 900€.
Has someone know some cheap fix?
