Twin 2005 F225 My gauges are not displaying water temp or oil pressure. I assume a wiring issue any ideas or resources to check out. New to four stokes but learning quickly. Already replaced belt, tension assembly, Cam Sprocket and epoxied hole in the thermostat housing.
2005 F225 Guages no Oil or water temp reading
if your engines are "2005 Model Year" - F225TXRD or F225TURD
then they are compatible only with "conventional" Yamaha gauges
such as the classic "multifunction" tachometer
which will give you rpm, trim position, & hours -
but for oil pressure and temp,
it can only display a warning indicator,
not a numeric value or bar scale 'reading'
Thanks very much for the the info they are F225TXRD. I was looking into possible NMEA 2K since the engine has the Blue and white connection the cost is close to $1K not even sure it would give me that info is it doesn't supply it to the gauges
Thank again for the reply.
