2005 F90 25" shaft convert to 20"
  • 2005 F90 25" shaft convert to 20"
    Hi all. I just got a 2005 F90 TXRD
    This is an extra long shaft 25". Is it possible to convert it to a 20" Shaft?
    Looking at the motor from the outside and in my repair manual I can see that it has the factory 5" section or spacer. I hope someone here can help answer my questions. Thanks.
    Yes, You'll need at least a shorter drive shaft (part #10), remove the extension piece, mid section shift shaft I believe would need replacing for a shorter one...
    2005 F90TXRD Yamaha Outboard LOWER CASING DRIVE 1 Diagram and Parts
      And the tube for the water pump needs to be different.
      Probably cheaper to mount the motor on a five inch jack plate.
