I have a ZV200TLRC. I checked the ECM peak voltage output (using a DVA adapter) going to the coils as shown in the manual on page 8-15 and got 16 volts. The manual says it should be 270 v when cranking. The pulser coil tested ok with all readings 3.8 to 4 volts when cranking. Is 270 volts correct? Does this mean my ECM is bad? Seems unlikely but this thing just does not like cold starts.
HPDI ECM Peak Voltage
does that mean do not disconnect the wires from ECU to the coils?Originally posted by Keithbaja View PostDVA from ECM 160 min. 260 DVA above 1,500 rpms. Don't test
with ECM disconnected or damage to ECM could occur....
Only check circuits loaded?
I am suprized those motors use Capacitance discharge ignition with ECUs, I would have thought they would have used the 12V like cars
They use a transistorized ignition system. Like most modern cars do.Originally posted by 99yam40 View Post
