I have a 2003 Merc/Yamaha 225 4 stroke. the Merc model number is # 1225F234K that I recently purchased used. In going over the engine I discovered (maybe too late?) that water is leaking from the port side thermostat housing. It appears that the rubber gasket has been squeezed or pushed out.
Has anyone ever experienced this problem before? I have ordered replacement thermostast but am wondering is this is a sign of a much deeper problem.
Also, when I go to replace the thermostat will I have to pull off the intake manifold or is it possible to replace them with in place. Clearly I would like to avoid removing the intake manifold if possible, less things to drop of parts to lose
