i HAVE A 2003 YAMAHA THAT SEEMS TO RUN RICH AFTER IT WARMS UP AND GOES INTO CLOSE LOOP.
i'VE CHECKED THE FUEL PRESSURE AT THE RAIL 35 -36 PSI RUNNING.
I'VE CHECK THE BARO SENSER &TPS SEEM TO BE IN RANGE.
AND THEN I CHECKED THE O2 SENSOR i COULDN'T GET IT TO COME ABOVE .3 VOLTS RUNNING AND WHEN I TAKE IT OUT AND USE A PROPANE TOUCH ON IT THE BEST IT WILL COME UP TO IS .4 VOLTS AND THE HIGH SIDE .
DO YOU THINK THE O2 SENSOR IS BAD AND CAUSING THE RICHER CONDITION ?
I KNOW ON VEHICLES THAT VOLTAGE WILL TELL THE ECM TO RICHEN IT UP AND OR THROW A CODE, i WISH THIS MOTOR HAD A DATA STREAM SO i COULD LOOK ATY EVERYTHING WHY ITS RUNNING.
IF YOU COULD GIVE ME SOME IDEAS THAT WOULD BE GREATLY APPRECIATED
PAUL
PAUL
