Need a little help
I have an 18 foot boat and when I'm out *****ing, I want to run it as slow as possible, so just clicking it in forward gear is the speed I need. My motor will run for about 4 to 6 minutes and then start to shake a little and eventually die. I'm pretty sure its loading up. It will start right back up with no problem and I can see a little smoke, but not much. It wont run in gear below 10 (hundred) RPM for more than 6 minutes, then slowly the RPM's drop more and more and then it dies.
About one year ago I had the entire fuel system cleaned, new injectors and vst box was removed and cleaned, new fuel/water separator, new fuel pump but only one.
This is the first time I used it to ***** at idle speed so I never noticed it had a problem. Other that that it runs perfect.
Does anyone know what the problem could be?
