Ox66
  • Ox66
    Hi. I have a 2000 OX66 that will idle great with the engine cowling off but starts to loose rpms and stalls when I put the cover back on. Tech will not be available for 2 more weeks. I did all the usual, filters, lp fuel pumps, even chased down all the fuel lines. Any ideas. Also have a new o2 sensor.
    Have you checked the air intake system on the cowling?
    Any signs of the cowling interfering with components mounted on the motor?
      Ditto to the above. Sounds like an air restriction in the cowling intake.
        maybe exhaust gases leaking out under cowling and getting sucked into the intake
          No blockages or interfere. Took the intake cover off and cleaned it real good but still the same problem. However. This time it did the same with the cowling off.
            Hook up a portable tank directly to the engine and see if the issue goes away. If it does, work backward (old fuel lines, bulb, tank pickup, vent system, etc). If the problem persists, you know the issue is at the engine. Check fuel pressure.
              had this exact issue on a motor. only saw the exhaust leak by pure luck. started it early one morning and saw the puff of smoke due to condensation.. been spending all my time looking at air intake system
              fixed exhaust and it ran like a champ.
                where was your exhaust leak and how did you fix it?
