Hello, I have a 2011 F90TLR on a 2007 Carolina Skiff 198DLV. I bought the bought used three years ago and have had no issues with engine, which looks brand new.
Late last year, I changed the oil, oil filter and large and small fuel filters with Yamaha products. I have used the boat probably 10 hours since.
I buy non-ethanol gas when I can and put in ethanol treatment when I cannot.
Three weeks ago, a friend and I took it out on the lake. It ran fine for about 90 minutes. As we neared the landing, the engine died and we had to paddle in. It wouldn't restart.
When I got home, I found there was no gas in the fuel filter on the side of the engine. I checked the fuel tank and found the vent screw closed. I loosened it, pumped the primer bulb and the small filter filled up with gas.
The boat started, but idled roughly.
Last weekend, I took it out again and I checked on a couple of deck items while my wife idled us away from the landing. The motor died and wouldn't restart. We had to get a tow back to the landing.
I checked the small fuel filter and it was full.
Then, I checked the oil dipstick and gas-diulted oil came rushing out.
When I got home, I looked around on the interenet and found other folks had the same problem. The suggested fixes always included replacing the thermostat, suspected of running the engine too cold.
I drained the engine oil and replaced with some Castrol 10w30 for testing. I also replaced the spark plugs. The engine started but idled roughly. It seemed to run OK if given throttle and there was no excessive smoke.
I can understand if the thermostat can be bad, but why the rough idle? I ordered a YDS software and cable kit that got here yesterday. In static tests, you can hear the fuel pump and injectors energizing.
I did tests with the engine running and nothing jumps out as wrong from the data there.
Also found the number of hours on the engine: 334.
I found another thread on this site where another owner with the same engine had the same issues and he discovered the diaphram in his fuel pump was in pieces.
So, it seems possible that with the fuel tank vent closed, it could have strained the fuel pump and I'm going to inspect it later today.
Am I thinking straight on this?
I'll also order a thermostat for preventive maintenance and will do a leak-down test. Waiting on a long-reach adpater for the spark plug hole.
Thanks for any insights on this.
