Hello, I am new to the forum.
I have twin F250s and am about to do the annual service on them, 700 hours.
My mechanic has already changed out the impeller kits and gear oil, but I am going to tackle the rest on the list. Have done the oil and filter changes on previous I/Os that I have owned, but this will be the first time on an outboard.
I plan to use my oil pump to pump out the engine oil rather than draining it. It seems to do a good job, someone please tell me if there is a downside to this. I have heard it helps to tilt the engine up to get most of the oil out?
My main question will be changing out the in-line fuel filter and the oil filter. Any tricks to these items, does it help to do one before the other, etc. I will pump or drain the oil before the oil filter comes off.
The inspection items on the list are:
spark plugs (what should I look for)
timing belt (ditto)
thermostats (ditto)
Rest of the inspect and replacement items seem like I can handle.
I am sure there are many threads on this, but just wanted to get a post up.
thanks in advance for the help and advice!
timing belt (ditto)
thermostats (ditto)
