225Turd frustration
Hi fellow boaters,
Have what I believed to be a fuel delivery problem which has been intermittent for a couple of seasons now.(50hours)
Engine bogs at 3000 rpm and sometimes when ball is squeezed revs up again?(other times no change)others times start up and up 5200 rpm without problem for short runs.
some insight to what I have tried pulled and cleaned VST (looked spotless) change f filter and water separator (10micron),filter before lp pump,primer bulb, low pressure pump checked line from tank to water separator and loosen check ball in anti siphon valve. Pulled line after LP pump and filled a 2 gallon gas can in no time.
looked at several blogs with the same engines and problems but never is there confirmed fixes.
Please lend a hand and I will post what the final fix is.
Hi fellow boaters,
