2006 f40
  • 2006 f40
    any help would be appreciated. i recently purchased a f40 and it’s bogging under lid at 1/4 throttle. did some research seems to be a common issue. took to my mechanic he cleaned carbs said they weren’t really dirty reassembled put back on motor same thing still boggs. during my research i found this mod that everyone says fixes the issue and that was to install f25 jets. so i ordered all new jets and gaskets. he cleaned again in a ultrasonic cleaner and installed new jets. same thing still bogs under load. he had a brand new prime starter assembly laying around threw it on it. no difference. he installed new plugs, fuel pump, and used brand new gas. we’re both at a loss with it. anyone have any suggestions? thia
    Is the timing advancing as it should when advancing the throttle.
    make sure idle and WOT timing is in spec and doing what is should
      yes he checked it today it is advancing
