The engine will not start. Yamaha 2014 four stroke 250hp motor. While fishing the engine quit running. I was able to start it for approximately 30 seconds while sputtering and then it has not started since. These are the things I have done to fix the problem.
1. Checked for air in the lines... no air in the lines
2. Ran diagnostics, no issues shown
3. Just in case replaced the water separator...
4. Replaced the engine fuel filter
5. Checked the low press pick up pump... feeds fuel appropriately
6. Removed the VST, cleaned the container and replaced both fuel filters
7. Checked the High pressure pump... It is delivering a good amount of fuel to the injectors.
8. Checked all injectors, (did not measure pressure) all delivering a good amount of fuel
9. Checked spark on all plugs all have good spark, (also changed all the spark plugs)
10. Checked compression.... all cylinders are good
11. Checked the kill switch... normal
12. Checked all fuses... all good
12. Have not checked timming
13. The engine did overheat prior to the main problem, but I replaced the complete impeller assembly.
14. Have not changed out the thermostats, could this cause the engine not to start??
15. HELP, PLEASE
15. HELP, PLEASE
