1st test in water
hey guys just purcahsed my first boat, its awesome and it has a old 2 stroke 40hp yammi starts first go idles fine but when im in full throttle the power fluctuates every like every 2 seconds not drastically but its noticeable in noise and feel when in the boat...i noticed that one of the fuel lines on the 3rd carb had a slight fuel leak (slow drip) from the hose could this cause that problem?(replacing all fuel lines real soon)....I need help on adjusting the timing and the carbs but i have no clue on where to begin if someone could help me with some info that would be great
2nd test
replaced all fuel lines... started first turn of the key and then died after 15 seconds adjusted each carb half a turn out equally and now it idles smoothly..
in the water it did the same thing from 1st run but while a mate of mine was on full throttle i adjusted the timing slowly and the the problem went away and ran very smoothly at full throttle i locked it off there and adjusted timing aswell for idle and adjusted the carbs its a tad bit shaky on idle and when in gear, might do that tomorrow and work on the idle to get it smooth
can someone help me out on how to adjust timing and adjust the idle properly..
2nd test
