I have question about low usage of my Yamaha 2019 F40LA outboard. I really do not use it often since it is not used in the winter months. I use it 2-3 weekends in the summer and fall during the waterfowl season. Probably use it 8 times from May to September and 10 times during duck season. I am always in shallow water and run 1/4 to 1/2 throttle. I do take 5-10 minutes to run at full throttle at the end of each outing to get the engine running before going home. I run in fresh water, flush 15 minutes with the flush port when I get home, change the gear oil, engine oil/oil filter, spark plugs, fuel filter (on engine only), full water pump impeller kit change and thermostat yearly. I winterize with the gas/EFI fogging oil and run the motor with a 55 gallon drum supplied with water from my hose. The thing hates water muffs.
I am concerned that low usage is going to be a problem when my 6 year warranty expires. I bet I run this motor a maximum of 20-25 hours a year. I do use non ethanol fuel, add Yamaha fuel conditioner and Ringfree to every tank and use a fresh batch of treated gas at the start of the season. What do you guys think and suggest I do to prevent issues. The boat and motor are always stored in my home garage. Thanks for your replies.
